Determine model of Cisco Wireless device from Serial number
I am working with a client to build upon existing wireless infrastructure.  I am advised of the S/N ( GKS143800LM ) but told model identification is not visible.  The unit is mounted in a hard to reach location.
Is there a way to get to the model of the device from this S/N?
Thanks.
Jeff
Bronze
Hello Jeff,
I was not able to pull a model for that serial number, but after checking some of the wireless devices might have some helpful information.
I located a WAP200 and WAP2000 which both have GKS serial numbers. The key difference between these APs is that the WAP2000 is larger and in a metal case, with the WAP200 being smaller and in a plastic case.
I hope this information helps.
Re: Determine model of Cisco Wireless device from Serial number
I appreciate the help.. thank you
Response via speech recognition on Jeff's phone
1429
