Devices keep disconnecting from WAP300N connected to RV180 Router
We are a small business and we are using WAP300N as an access point to which about 40 devices are connecting daily. The AP is connected to a RV180 Multifunction VPN Firewall Router. Since we have this infrastructure, every single day there are clients who are been disconnected and cannot reconnect for a while until we disconnect another device.
The router has been set up as a DHCP server with a pool 192.168.1.2 - 192.168.1.127. However, I set up all clients with a static IP outside the pool.
The access point has the following settings:
Operation Mode:Access Point
MAC Address:XXXXXXXXXXXXXXX
Network Name (SSID):XXXXXXXXXXXXXXXXX
Network Mode:2.4G Mixed
Radio Band:2.4 GHz
Channel:1
Channel Width:20 MHz Only
Security:WPA2 Personal
SSID Broadcast:Enable
The routing mode of the Router is set to Gateway (NAT). Can you please advice what can be done so we can resolve the issue? I saw similar posts in the forum but none of them provide solutions.
Kind Regards,
Mariya Stancheva
299
