05-09-2014 01:51 AM
Hello Cisco,
Now Im a big Cisco fan so i replaced our Airport access points in the house with the WAP561.
My main problem is that since i did that, once in a while (if i had to guess every couple of hours) I have our laptops, iphones disconnecting and then it takes the device a while to be able to reconnect to the access point (unless you manually disable wifi and enable it again).
Ive been trying to figure out how this would be possible but so far I have no clue.
Running Firmware 1.0.4.4, The Radio is set to 20Mhz (also on 20/40 same result) with a static channel (6), there is no other wifi ssid's around us so that cant be it. We use WPA2 keys and all the other settings are pretty default. (No QOS, No VLAN, No guest)
We didnt have this problem at all with Airport express/extreme from Apple, all devices stayed connected forever.
I hope someone can help me cause this is seriously annoying.... i want my devices to stay connected.
The only thing i can find in the logs is this:
May 9 2014 10:46:37 | info | hostapd[2135] | wlan0: WPA STA 60:03:08:92:7a:00 pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 9 2014 10:46:37 | info | hostapd[2135] | wlan0: IEEE 802.11 STA 60:03:08:92:7a:00 associated with BSSID 18:9c:5d:39:67:00 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 9 2014 10:46:37 | info | hostapd[2135] | wlan0: IEEE 802.11 Assoc request from 60:03:08:92:7a:00 BSSID 18:9c:5d:39:67:00 SSID Mnet | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 9 2014 10:46:37 | info | hostapd[2135] | wlan0: IEEE 802.11 STA 60:03:08:92:7a:00 deauthed from BSSID 18:9c:5d:39:67:00 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 9 2014 10:46:19 | info | hostapd[2135] | wlan0: IEEE 802.11 STA 54:e4:3a:2f:93:78 deauthed from BSSID 18:9c:5d:39:67:00 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 9 2014 10:46:14 | info | hostapd[2135] | The wireless client with MAC address 54:e4:3a:2f:93:78 has been successfully authenticated. |
May 9 2014 10:47:02 | info | hostapd[2135] | wlan1: IEEE 802.11 STA 54:e4:3a:2f:93:78 deauthed from BSSID 18:9c:5d:39:67:10 reason 4: Disassociated due to inactivity |
05-10-2014 06:42 AM
05-10-2014 10:51 AM
Does Cisco actually give anything about their customers these days or is the only answer: Make a support ticket or not reply at all?? Im a Cisco user/fan/engineer for years and was hoping Cisco would take things seriously, ive seen a lot of WAP problems on these forums all related to Apple devices disconnecting with inactivity over and over, and none of the topics ends with a good result. I was hoping for once this could be fixed!? Or are we, the customers, seriously have to look at other brands? Thank you.
05-13-2014 04:07 PM
Hello Michiel,
Sorry for the late reply.
Just a couple of questions so that I can try and help with resolving your issue. On your configuration for the WPA561, under LAN -> VLAN and IPv4 Address: Do you have the Untagged VLAN checked or unchecked?
During a time when the WAP561 is not responding to DHCP request, can you still get to the GUI using a PC that is hardwired on the network? If you can could you do a packet capture using the capture on the WAP and capture from the BRTrunk and Eth01.
However if we find anything once we get started, it may be more advantageous to have you open a case and actually work with one of our Engineers directly.
But lets get this information to start and see what we can find.
Eric Moyers
05-14-2014 05:52 AM
Untagged VLAN: Enabled
Should that be off?
Yes i can still get to the GUI, the strangest part is that other non apple devices keep working fine aswell also over wifi.
Did some more testing today (Whenever i use a non cisco access point (ASUS, Apple) it keeps working fine):
May 14 2014 14:47:36 | info | hostapd[874] | The wireless client with MAC address 54:e4:3a:2f:93:78 has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:47:36 | info | hostapd[874] | wlan0: WPA STA 54:e4:3a:2f:93:78 pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:47:36 | info | hostapd[874] | wlan0: IEEE 802.11 STA 54:e4:3a:2f:93:78 associated with BSSID 18:9c:5d:39:67:00 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:47:36 | info | hostapd[874] | wlan0: IEEE 802.11 Assoc request from 54:e4:3a:2f:93:78 BSSID 18:9c:5d:39:67:00 SSID Mnet | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:47:34 | info | hostapd[874] | wlan0: IEEE 802.11 STA 54:e4:3a:2f:93:78 deauthed from BSSID 18:9c:5d:39:67:00 reason 1: Unspecified Reason | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:47:34 | info | hostapd[874] | Station 54:e4:3a:2f:93:78 had an authentication failure, reason 17 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:45:35 | info | hostapd[874] | The wireless client with MAC address 54:e4:3a:2f:93:78 has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:45:35 | info | hostapd[874] | wlan0: WPA STA 54:e4:3a:2f:93:78 pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:45:35 | info | hostapd[874] | wlan0: IEEE 802.11 STA 54:e4:3a:2f:93:78 associated with BSSID 18:9c:5d:39:67:00 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:45:35 | info | hostapd[874] | wlan0: IEEE 802.11 Assoc request from 54:e4:3a:2f:93:78 BSSID 18:9c:5d:39:67:00 SSID Mnet | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:45:35 | info | hostapd[874] | wlan0: IEEE 802.11 STA 54:e4:3a:2f:93:78 deauthed from BSSID 18:9c:5d:39:67:00 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
May 14 2014 14:45:25 | info | hostapd[874] | wlan0: IEEE 802.11 STA 54:e4:3a:2f:93:78 disassociated from BSSID 18:9c:5d:39:67:00 reason 8: Sending STA is leaving BSS |
05-14-2014 08:05 AM
05-14-2014 08:28 AM
Changing WPA/WPA2 and so on doesnt do anything, I tried both, or one of the other, same result.
Also what i have noticed is that it does connect to wifi but it wont do anything on the internet for some strange reason. So it does connect and gets an IP but wont connect to the internet untill i disable/enable the wifi on the iphone like 3x and sometimes it just starts working for a few minutes and then it stops working again.
This is definitely a WAP561 bug since I just tried a ASUS access point, Airport and a Netgear and with all those brands i have absolutely no problems, which is a shame cause i was really hoping Cisco would make better products.
Ill try changing Multicast to 54 now.
05-14-2014 08:33 AM
Just tried it setting it to 54 (multicast rate) does exactly the same, it works a few times but when iphone goes in standby and you put it back on, it connects but cant connect to internet.
05-27-2014 08:47 AM
So far the newly released WAP5xx_1.1.0.4 firwmare seems to run a bit better, im gonna do some more testing.
08-05-2014 04:29 PM
Eric, I'm experiencing the same issue Michiel reported. I'm running the latest firmware and made sure my settings matched the suggestions you posted here however the problem is still ongoing. Any further suggestions?
08-14-2014 02:57 AM
I have switched to Ubiquiti Unifi access points cause i was done with the amount of bugs and lack of software updates here, sorry. Since im on Unifi... 0 problems and great amount of updates.
08-14-2014 08:45 AM
That is our exact plan too. Thinking of the using the AP AC units from Ubiquiti with a VM controller. Which APs did you go with?
11-24-2015 10:58 PM
Hello Eric,
i am also experiencing the same issue on WAP121 N.Tried everythin as per above suggestions.The access to local server is blocked.Please help me in resolving the issue the users are getting disconnected frequently.
Aditya Asati
11-25-2015 07:58 AM
Hello, Thank you for eaching out here on the Support Forums. This can be a very involved issue to troubleshoot. I would first suggest that you call in and open a ticket in order to work directly with a support engineer in order to resolve this more quickly.
Beyond that if you decide to try and solve through the forums. I would need some more information in order to help.
What does your network look like? Router Switches, # of devices, # of Wireless Devices? VLANs, IP's? What is doing the DHCP? Do you have any packet captures?
IF you call in one of our engineers would be glad to work with you to get all of the information and also help troubleshoot.
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
11-25-2015 10:24 PM
i have opened the case cisco tam is working on the issue.
Reagards
Aditya Asati
