DHCP scope and VLAN Switch SG300
Hello All,
I did the config below but uneble to obtain the ip from the subnet scope 10.10.9.0. The switch is in the layer 3 mode.
Any idea? or suggestion?
no spanning-tree
vlan database
vlan 2
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
interface vlan 2
ip address 10.10.9.1 255.255.255.0
exit
interface vlan 1
ip address 10.10.13.11 255.255.255.0
exit
interface vlan 2
ip dhcp relay enable
exit
interface vlan 1
no ip address dhcp
exit
ip helper-address all 10.10.13.222 37 42 49 53 137 138
hostname switchd2fac1
no snmp-server server
interface gigabitethernet11
switchport mode general
switchport general allowed vlan add 2 tagged
switchport general acceptable-frame-type untagged-only
exit
1 REPLY
I think you need a couple more commands
! global config
ip dhcp relay address 10.10.13.222
! (then
show ip dhcp relay
! to display status)
unless you want to forward all udp on those ports, you may not need  this command
Dan
2149
