10-25-2010 11:45 AM
Dear Friends,
I am in search of a access point with below specification, so please let me know that which model has this functionalities.
. Wireless Access Point:
* No of port should be 10Base-T/100Base-TX Ethernet
* Standard should be IEEE 802.11g, IEEE802.11b, IEEE 802.3, IEEE 802.3u, IEEE 802.3af(PoE), 802.1q(VLAN) , 802.1X(Security authentication), 802.11i ready (Security WPA2), 802.11e ready (wireless QoS), 802.11F(Wireless roaming)
* LEDs should be power, PoE, Wireless, Ethernet
* Web Management should be built-in web user interface for easy browser-based configuration (HTTP/HTTPS)
* SNMP Support should be SNMP version 1, 2c, 3
* Operation modes should be access point made, point to point bridge mode, point to point multipoint bridge mode, repeater mode
* External antennas should be 2 (omni directional) SMA detachable
* Security should be WEP 64-bit/128-bit, WPA-PSK, WPA2-PSK, WPA-ENT, WPA2-ENT
* Access Control should be wireless connection control: MAC-based
* Wireless Security monitor should be Intrusion alarms(e.g. rogue client detected, spoofed MAC address) Denial-of-service alarms (e.g. duration attack, association table full) vulnerability alarms (e.g. access point is not using encryption, access point is broadcasting SSID)
* Power should be 12V 1A DC input, and IEEE 802.3af compliant PoE. Maximum power draw should be 3.36W
Solved! Go to Solution.
10-25-2010 11:55 AM
Hello Shekib,
All you did was describe the WAP200.
It fully fits in your description.
Please check it and see with your eyes.
I hope i helped you.
Regards.
Andrey Cassemiro.
10-25-2010 11:55 AM
Hello Shekib,
Regards.
Andrey Cassemiro.
10-25-2010 12:15 PM
YOU REALLY HELPED ME!!!!!
THANKS, YOU ARE OUTSTANDING.
REGARDS,
SHEKIB
