Community Member
How do I convert AIR-LAP521G-A-K9 to to work as autonomous?
Lots of documentation shows that you cant do it using CCA, but I cant seem to find a description of the process anywhere.  Any help you can offer will be greatly appreciated.
Thank you.
1 REPLY
Bronze
Re: How do I convert AIR-LAP521G-A-K9 to to work as autonomous?
Please open a TAC case they should be able to help you out - there are some console level CLIs required and it would be best if TAC guided you through this
1853
