Community Member
it work!
have a new wap4410N access point. i log into the the default IP address 192.168.1.245 only showing ( it work! ). so how can i enter the admin page please help me i need to change wi fi password and name
and i using os x
Community Member
it work!
Hi Ramzan,
I think the problem is because of the browser security certificate. What is the browser you are using to access the device?
Phanikrishna
it work!
Hello Ramzan,
From your description, it seems like you might be accessing incorrect IP address. Typically "it works" is a page displayed when you access a Samba/Apache server without much configuration. Can you please verify the address again? You can also check the MAC address of the AP and compare that against your ARP table to verify if you are accessing the correct device.
Hope this helps.
Nagaraja
Bronze
I'd agree with what Nagaraja
I'd agree with what Nagaraja explained.
Also, could you please let me know what Firmware Version are you using?
487
