02-25-2009 10:11 PM
I ordered a WLC526 for a customer. Howevever, it didn't come with brackets to mount it into a standard 19" rack.
I called our distributer support. They said that it's intended to be a desktop unit. However, it has screw holes on the side of it.
Does anyone have a part number for brackets to mount the WLC526 into the rack?
Ben
Solved! Go to Solution.
03-02-2009 06:08 AM
The 526 controller doesnt have its own brackets, but the controller housing is the same as the UC500 housing, so you can order the brackets for the UC500.
ASA5505-RACK-MNT for Rack
ASA5505 -WALL- MNT for Wall
Mike
03-02-2009 06:08 AM
Mike
03-03-2009 05:03 PM
Thanks alot.
Those part numbers are actually for the asa, but i hear they will work on the WLC526. The actual part number for the UC500 rack mounts is ACS-UC500RM-19=.
I found that the "UC500" part number quite a bit less expensive than the ASA part number.
Ben
