Need a solution for 250+ Wireless Clients
We have a new client that we need to provide wireless access (across multiple locations in a single building) for, but they require several hundred users connecting simultaneously for internet access. It is a convert venue.
Up until now we have been making do with short DHCP lease times, and WAP561 access points with Single Point setup, and it works OK, but now the solution is expanding.
Any suggestions on how we can fulfill this?
Thanks!
Hall of Fame Super Gold
What kind of "budget" are we
What kind of "budget" are we talking about here? Do the client want to go down the road of using the enterprise-grade wireless access point or SOHO?
Hi Leo,Unfortunately the
Hi Leo,
Unfortunately the budget isn't great, the ideal scenario would using multiple WAP561 units, with a SG200 or SG300 series switch. We are using Sonicwall firewalls (shame!) to handle DHCP currently...
If the dedicated controller and then managed AP's was good value, then we might be able to get it over the line...
68
