Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
P2P communication blocked - WLC526
Peer-to-peer communications are being blocked via wireless using WLC526 and LAP521's on same SSID. How do I enable P2P communications?
Bronze
Re: P2P communication blocked - WLC526
Depending on the P2P applications, you can configure extended access-lists and block the P2P communication.
refer to the following document of cisco. you can do the same sort of blocking on the routers to prevent p2p applications..
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a00801e419a.shtml#edonkey
Basically I want to disable the blocking entirely. How do I do that with the WLC526? By the way, I tried thelink you provided, but it didn't work.
254
