Community Member
Power Injector for a AP541N?
Is there a power adaptor that you can purchase to use with the AP541N.
Lisa
Hall of Fame Super Gold
Re: Power Injector for a AP541N?
Community Member
The AP541N is a the wireless access point not a phone so these won't work with this. I believe the aironet range doesn't work with the AP541N but need some clarification?
Lisa
The AP541N power draw is 10w while the power injector can push out 15.4w.
Otherwise, you can also opt for AIR-PWRINJ3 or AIR-PWRINJ4.
Community Member
So what is the exact type can be used, because it is not clear from this forum.
In an other thread somebody said that "Tried using the AIR-PWRINJ3, but the power adapters plug that came with the AP541N does not fit the injectors connection"...
https://supportforums.cisco.com/message/3087372#3087372
Tibor
1956
