Problem with Workgroup Mode WAP 321
Hello i want to setup the WorkGruop Bridge feature at the WAP 321.
The problem is that i can´t choose the the Static WEP as Security. Does someone know the Problem?
Anton Fischer
1 REPLY
Hello Anton,
You will not be able to configure WEP as the encryption when in the Wireless "N" mode. You can only configure WEP in "B" or "G" mode.
Hope this helps.
Nagaraja
102
