Signal strength only can achieve to 54Mbp for WAP4410N?
Customer recently purchase WAP4410N, the signal strength only can achieve to 54Mbp ( even using the newer laptop with N-wireless card).   I would think the signal at least can get 100-200 Mbp for N-router.  Please help to check on this issue, because we bought for N-router, is to improve signal strength to 200Mbp, and now the signal is the same as the G-router (Aronet 2100).   Our users are quite disappointed.
1 REPLY
Silver
Re: Signal strength only can achieve to 54Mbp for WAP4410N?
If the WAP4410N was purchased recently i would give us a call at 1-866-606-1866
It could be something small (setting,firmware,etc) or it could possibly be a hardware issue.
   Jason
649
