TPE-113GI and WAP321
My WAP321 has the power light red when connected thru the injector TRENDnet TPE-113GI. Are the devices compatible? The WAP works via power adapter but I need the PoE.
1 REPLY
Silver
Can you connect through
Can you connect through console cable and check the the CLI monitor displays?
48
