Troubles configuring wireless interface on 1811W.
Hello to all
I have the following issue: I managed to configure the Wlan radio interface of a 1811W and I am using WPA2/PSK. But even I connect to the router via wireless it seems that there is no communication between the computer and the other interfaces; also DHCP is not assigning me an IP.
I should mention that I am not a cisco expert but I like to think that I have some sort of knowledge in IP networks. Can someone enlighten me?
Here is the configuration:
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$okVP$DM2WzthHyExQEVDHHY1
no aaa new-model
dot11 ssid IvanTurbincaN
   vlan 3
authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 096D420415135A4D
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.123.200 192.168.123.254
ip dhcp excluded-address 192.168.23.200 192.168.23.254
ip dhcp excluded-address 192.168.123.100 192.168.123.126
ip dhcp pool DHCP_Pool
   network 192.168.123.128 255.255.255.128
   default-router 192.168.123.254
   dns-server 8.8.8.8
ip dhcp pool DHCP_Pool2
   network 192.168.23.128 255.255.255.128
   default-router 192.168.23.254
   dns-server 8.8.8.8
ip dhcp pool DHCP_PoolN
   network 192.168.23.0 255.255.255.128
   default-router 192.168.123.126
   dns-server 8.8.8.8
ip dhcp pool DHCP_PoolNexit
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
bridge irb
bba-group pppoe global
interface FastEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Dot11Radio0
no ip address
encryption vlan 3 mode ciphers aes-ccm
ssid IvanTurbincaN
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Dot11Radio0.1
description home
encapsulation dot1Q 3 native
no cdp enable
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip address 192.168.123.254 255.255.255.128
interface Vlan2
ip address 192.168.23.254 255.255.255.128
interface Vlan3
no ip address
bridge-group 3
interface Async1
no ip address
encapsulation slip
interface Dialer1
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username bv18820254 password 7 055A5F57731B1D5A
interface BVI3
ip address 192.168.123.126 255.255.255.128
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
access-list 100 remark --nat--
access-list 100 permit ip any any
dialer-list 1 protocol ip permit
control-plane
bridge 3 protocol ieee
bridge 3 route ip
line con 0
password 7 08004E5B011413055D45
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password 7 072E2359416161C5A4D
login
webvpn cef
1 REPLY
Ok I have found 1 bug but the issue is not entirely solved.
Instead:
   dns-server 8.8.8.8
It should be:
   network 192.168.123.0 255.255.255.128
   dns-server 8.8.8.8
Now I get an IP address but I have no routing to the other interfaces.
I can ping only
BVI3 (192.168.123.126)
Any ideeas?
544
