09-11-2013 10:40 AM
I am looking into purchasing WAP121 AP product and understand it supports 802.1x RADIUS.
For an intergration with NAC product from Bradford, I need to know if WAP121 supports RADIUS COA standard or at least there is a way to disassociate a client through CLI command.
Thanks in advance.
-chang
09-16-2013 11:21 AM
Dear Chang,
Thank you for reaching the Small Business Support Community.
None of the Small Business access points support the RADIUS CoA nor have CLI access, these are all GUI configurable devices with just the RADIUS feature.
I suggest you to look for an eterprise device and inquire about this feature on the wireless support community forum;
https://supportforums.cisco.com/community/netpro/wireless-mobility
Please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
09-20-2013 08:16 AM
Hi Chang,
Cisco Small business access points don't have CLI access it can be accessed only via GUI. You can check the features related to WAP 121 on cisco portal. I am providing the link please check it.
Phanikrishna
