WAP 321 disconnecting all associated clients
Hi Support,
I am a newbie technical support. Currently, I encountered a issue about WAP321 that will occasionally disconnecting all the clients(about 7 clients only) in one shot and cannot connect back at all. However, after login to the Web Gui and reboot the WAP321. It is able to connect again.
I had upgrade the firmware to 1.0.4.2 but the problem still exists. The AP is using only WPA2-Personal.
The environment of the AP is like this:
Internet->Watchguard Firewall (with AP too but different SSID with the WAP321, flat vlan) ->switches and WAP321
Is that any misconfiguration of the AP or the network environment cause this issue?
Another problem is the time of the AP cannot be fixed. I had tried either set the time using NTP (port 123 is opened in firewall) or manually input but it will revert back to 1999 after reboot.
Thanks in advanced!
Everyone's tags (1)
1081
