WAP 321 - Other devices gets disconnected when I'm attempting to use Captive Portal
farmen8632
Hello all,
I just setup this WAP321. The normal Wi-Fi works fine, its fast and good connection. So thats great.
But when I try use Captive Portal from my smartphone,  every other devices hooked up to the network, is getting disconnected. A big fat red X is appearing on top of my Network icon in tray (windows 7).
In order to restore my internet, I need to turn of Wi-Fi on my phone.
One of the reason why I bought this WAP321, was because of the Captive Portal feature. So when I get visitors, they can access it without a code, not interfere with my network and not get access to my documents etc.
Any of you guys know where to look and how to solve this?
Here is a quick and noobish drawing of my network: http://cl.ly/image/45473W1C3C1U
This is the emulator for my router if you can use that for anything: http://event.asus.com/2009/networks/dummy_ui/en/ (Asus RT-N56U)
-Jonathan
jeffrrod
Level 4
Level 4
Dear Customer,
Thank you for reaching Small Business Support Community.
It's been defined as an open caveat ID CSCue24521 in firmware release v.1.0.4.2;
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap321/release/ReleaseNotesWAP121_321_104x.pdf
The work around is to reconnect the wireless devices, same thing you are doing. I suggest you since there is no public firmware version with the fix, to contact the Small Business Support Center;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
