07-19-2009 07:35 AM
Hi guys
I am TOTALLY incompetent in setting up wireless connections. I have a ADSL 512k connection via a Linksys WAG 300N modem router on the ground floor and it is linked by an ethernet cable to a WAP 4400N on the first floor.
Recently the internet connection on the first floor has started to become erratic.
Hence my questions
Many thanks.
Piet Bekaert
Dubai
Solved! Go to Solution.
07-20-2009 10:47 AM
Mr. Bekaert,
1. The WAP4400n needs to be physically connected to the main router (WAG300N). Make sure the Gateway and Primary DNS on the WAP4400n is pointing to the WAG300N (192.168.1.1) and set the wireless tab with a SSID differently from any wireless devices, but can use the same security mode and password.
2. To hard reset the WAP4400n you will need to hold the reset switch for 30 seconds and it will factory default to the 192.168.1.245 state with the default user name/password admin/admin
3. The WAP4400n should have the latest firmware if you have just purchase it. this is located in the WAP web interface under the Status Tab "Software Version" This is accomplished by typing in the address bar: 192.168.1.245. If you need to update latest firmware, you can find it at our CISCO website www.cisco.com/smb. The firmware for that unit should have the v1.2.14.
4. The PoE or Power over Ethernet is only used to power the WAP4400n device, this does not supply power to other devices that require PoE.
5. The helpline for your WAP4400n is in Saudi Arabia telephone# 800 844 5849.
I hope the above information is helpful
Sincerely,
Edgar
07-20-2009 10:47 AM
Mr. Bekaert,
Sincerely,
Edgar
07-22-2009 02:44 AM
07-22-2009 02:58 PM
Piet,
1. What Edgar means by "Make sure the Gateway and Primary DNS on the WAP4400n is pointing to the WAG300N (192.168.1.1)?" is for you to log into the WAP4400N by typing it's IP address (192.168.1.245) in your web browser's address bar and logging into it with the username and password. Once you're logged in you'll see the page below.
Once you're here you'll want to type the IP address of the WAG300N in the fields labeled "Default Gateway" and "Primary DNS".
07-23-2009 11:29 PM
Thanks for the suggestion.
Actually, thanks to the help of one of the Linksys (not the Cisco) home products helpine operators who decided to help me on this issue, despite the WAP 4400N being a business unit an not under his technical area, I was able to check that the unit had a software version 1.2.8 ETSI.
I tried to figure out which of the two upgrades I needed to upload, the 1.2.14 or the 1.2.14 ETSI. The latter one seems, according to the website, be specific for WAP 4400 N of Australia, Brazil, the EU, UK, Singapore, etc... My unit did not specify a geographical area following its model number. But I went along and uploaded the ETSI version and when prompted to reboot, I got a warning page to wait while this was ongoing. This warning page never ended, but when I checked 192.168.1.245 later on, I saw that the new software version was on. :)
Now, the questions are still what this ETSI stands for, and how the new software will improve the functionning of the unit? I still wonder if my problems of network strenght of penetration persist, if I should not just buy the WRP 160N or the WRP 610N????
Can anyone answer me on these issues?
Piet
07-24-2009 04:49 AM
The European Telecommunications Standards Institute (ETSI) produces globally-applicable standards for Information and Communications Technologies (ICT), including fixed, mobile, radio, converged, broadcast and internet technologies.
Products sold in more than one country would have to adapt to the standards of that country. So the HW can sometimes be the same, and only the image (software) will be different, as in your case to make it abide by and cooperate with other devices that should follow those standards.
Hope that helps.
