Wap 551 Cluster
I just put in my 6th 551 and it will not join the existing cluster.
Its working but broadcast with ciscosb as it wireless network.
It has not picked up the settings from the other APs
The password remains default cisco cisco.
Any ideas?  I am calling for help tomorrow, I need for this to work.
Tony
I set it up using the wizard.
1 REPLY
The biggest shock came when I
The biggest shock came when I opened the box and realized there is no port for an external power adapter. This item is POE only. I usually preconfigure APs in my test bench environment where there is no POE. I actually had to put this on the production network, check ARP tables for the MAC address to figure out the IP it was using, then use their web interface to configure.Once I got the IP address, Java configuration was fast.
22
