WAP121 disconnects clients
thomas.vogt11
Hello
I use two WAP 121 in my office. The two WAP121 are configured to a cluster and have the same SSID.
The problem with the WAP121 I have is, that they disconnect the devices, the device can connect, after a few seconds the devices are disconnect again. I do not know where the problems is comming from.
The firmware is the current firmware 1.0.6.5.
In the attachment there are the log file and a screenshot of the WAP121 information. May someone finds a hint for me how I can fix the problem. I would be very happy!
Cheers Tom
17 Replies 17
Can you disable bandwidth utilization and check user experience ?
BR/Rawa
It did not work, in the second equipment when it enters the cluster it continues to disconnect customers.
When it disables the cluster it fails to stop.
Att
Actually i changed to cisco wap 151 , by disabling bandwidth utilization now its fine , i hope cisco fix this issue permanently ,
BR/Rawa
