WAP321 and Radius authetication
hi,
I've been trying to get a Cisco WAP321 working with Radius authentication with a Windows 2008R2 Active Diretory server and I cna't make it work.
The etries in the WAP log are very vague:
Sep 25 2012 11:57:52 info hostapd[6247] wlan0: IEEE 802.11 STA 00:23:14:87:1e:f8 deauthed from BSSID b0:fa:eb:d9:2b:d0 reason 1: Unspecified Reason
Sep 25 2012 11:57:52 info hostapd[6247] wlan0: IEEE 802.11 STA 00:23:14:87:1e:f8 associated with BSSID b0:fa:eb:d9:2b:d0
Sep 25 2012 11:57:52 info hostapd[6247] wlan0: IEEE 802.11 Assoc request from 00:23:14:87:1e:f8 BSSID b0:fa:eb:d9:2b:d0 SSID LEXAP01
Sep 25 2012 11:57:51 info hostapd[6247] wlan0: IEEE 802.11 STA 00:23:14:87:1e:f8 deauthed from BSSID b0:fa:eb:d9:2b:d0 reason 1: Unspecified Reason
Sep 25 2012 11:57:51 info hostapd[6247] wlan0: IEEE 802.11 STA 00:23:14:87:1e:f8 associated with BSSID b0:fa:eb:d9:2b:d0
Sep 25 2012 11:57:51 info hostapd[6247] wlan0: IEEE 802.11 Assoc request from 00:23:14:87:1e:f8 BSSID b0:fa:eb:d9:2b:d0 SSID LEXAP01
Sep 25 2012 11:57:50 info hostapd[6247] wlan0: IEEE 802.11 STA 00:23:14:87:1e:f8 deauthed from BSSID b0:fa:eb:d9:2b:d0 reason 1: Unspecified Reason
Sep 25 2012 11:57:45 info hostapd[6247] wlan0: IEEE 802.11 STA 00:23:14:87:1e:f8 associated with BSSID b0:fa:eb:d9:2b:d0
Sep 25 2012 11:57:45 info hostapd[6247] wlan0: IEEE 802.11 Assoc request from 00:23:14:87:1e:f8 BSSID b0:fa:eb:d9:2b:d0 SSID LEXAP01
Sep 25 2012 11:57:45 info hostapd[6247] wlan0: IEEE 802.11 STA 00:23:14:87:1e:f8 deauthed from BSSID b0:fa:eb:d9:2b:d0 reason 1: Unspecified Reason
Where can I get some help with it ?
1 REPLY
Bronze
Dear Andres,
Thank you for reaching the Small Business Support Center.
I would first suggest you to make sure there is IP connectivity to the RADIUS server from the hosts needing to authenticate, second I suggest you to check on the firewall settings on your Layer3 devices on the way and make sure UDP 1812 and 1813 are opened.
Just to double check on the WAP321 RADIUS configuration settings I suggest you to look at chapter 6 of the admin guide;
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
Please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
882
