WAP371 Mounting
Does anyone know how to mount a WAP371 without the ethernet cable being visible?
Cisco designed the ceiling mount very poorly.
Agree with you, the connector
Agree with you, the connector is at the bottom and is visible. The 500 series is much better designed to hide the connector.
Hello there,
Hello there,
Have you considered using a right angle Ethernet cable such as this one?
http://www.amazon.com/Tripp-Lite-Gigabit-Molded-N204-010-BL-DN/dp/B005WKIR44
It could run straight up into a hole in the ceiling and plug 90 degrees to the WAP hiding it effectively
Best,
-Patrick Ayers
Nice workaround
Nice workaround
110
