WAP4410n can not access Web admin after upgrade
I have two WAP44's,  both with the well know drop connection problem.  I upgraded the firmware on one and now I can not access the admin webpage.
I read somewhere(information is so buried on this website it's a crime) the the new firmware uses DHCP as a default.  I added the 802.11 side's MAC to the DHCP server before the upgrade so I could talk to the AP after the upgrade.  After the AP rebooted I was able to ping the AP over copper but I can not open a webpage.
Did the default home page change names?
We still have connectivity across the bridge.  I'm using IE7.
What gives?
Thanks in advance
-Wade
1 ACCEPTED SOLUTION
Re: WAP4410n can not access Web admin after upgrade
Reset the device after the Firmware is upgraded and try again. To reset press the Reset button for approximately 10
seconds and try again with the default IP address of the AP.
Thanks for the reply,  I'll try that.  But like I wrote....the new firmware no longer has a default IP and instead uses DHCP,  or did I miss read that from some long lost PDF file off Ciso's website??
I'll give it a try tomorrow.
Thanks again
-Wade
If the device uses DHCP , then use the DHCP address to access the GUI.
1227
