Community Member
Wap4410N stopped working
I have 2 Wap4410n device. they both stopped working at the sane time. The SSID does not show up. I cannot ping either device. I tried to do a factory reset but it is not working. I have pushed the reset button for 30 secs up to 90 and nothing. Should the lights change when the reset happens? Any thoughts on what i can do?
thanks
1 REPLY
Hello How long have you had
Hello
How long have you had the WAP4410N's? Can you send the Serial Numbers for the two devices to me? I can look up to see if they are still in warranty.
Eric Moyers
.:|:.:|:. CISCO | Eric Moyers | Cisco Technical Support |
Wireless and Surveillance Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered
You can click my name beside the picture if you need to email me directly
102
