Wap4410n wireless vlan issues
I have problem with adding tow vlans with tow ssid like one for voice and one for Internet I tried to upgrade the firmware but still not getting the voice vlan works only
Is any body tried to configure multiple vlans with multiple vlans ?
1 REPLY
Gold
Hello Hassan,
Thank you for posting. Do you have a VLAN enabled router? You need to configure the VLANs in the router as well as the WAP4410N in order for it to work.
1152
