WET200 Compatibilty to Cisco AIR-CAP3502I-A-K9
Background:
I am attempting to find a reliable wired ethernet-to-wireless bridge device to work with the above AP and Controller using WPA2-PSK and AES.
The Linksys WET610N would associate/authenticate fine but suffered constant network drop offs as it reported @20-30 signal strength.
The WET200 site survey reports @80 signal strength but will not associate/authenticate to same network.
Both the WET610N and WET200 work fine using the same WPA2-psk AES settings to a Netgear WNDR3700 Wireless Router.test set.
Question:
Does anyone know of setting fix in the above AP or AP controller that would allow the WET610N to associate/authenticate work but
not the WET200?
Can anyone reccomend more robust ethernet/wireless bridge for this installation?
Everyone's tags (3)
1 REPLY
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
To the best of my knowledge none of our Small Business devices are certified to work with Enterprise devices. It is possible that by manipulating the settings that you could possibly get them to work. I know that some customers have been able to but there is nothing we are allowed to help with or support.
I am sorry for the inconvenience.
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
962
