Community Member
Which poe adapter will work with wap4410
I'd like to ask which Power over ethernet adapter will work in 100% with WAP4410 AP??
I tried to find solution but didn't get answer.
Tnx for replies
Community Member
Re: Which poe adapter will work with wap4410
For those times when needed, we found that by using the Panoptic PoE  Smart Adapter we successfully used their 802.3AF switch to power  non-standard APs, IP phones, cameras, etc. Their switches can go a full  15.4W PoE, the full distance.  http://www.panoptictechnology.com/network-smart-adapters/
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center.
Currently there is no Cisco certified POE injector for use with any of our Access Points. While there are several out in the market, none of them have been verified by Cisco to work with our equipment completely. Doing so, could do damage to your Access Point. Currently our best reccommendation would be to plug them into a POE switch that supports IEEE 802.3af standard. If you currently do not have one, We have several small inexpensive unmanaged POE switches that would surfice for this.
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
538
