12-18-2017 01:58 AM - edited 03-21-2019 10:49 AM
I'm in the process of setting up a HA pair and I' am unsure about a couple of things.
We have already got a standalone 5508 and I'am currently setting up a 2nd 5508 for resilience.
Both Boxes run 8.2.100.0 IOS.
1. Does the service port IP address need to be unique on the primary and redundant WLC?
I'm pretty certain this has to be unique but need clarification.
2. Would I be right in thinking that the management IP has to be the same on both the primary and redundant WLC ?
3. Once the second redundant WLC is in sync with the primary will it get the complete config from the primary WLC ? I believe this to be the case would but appreciate some clarification.
Many Thanks
Paul
12-18-2017 02:29 AM
Yes
Yes
Correct. The active controller will push the config to the standby controller.
12-18-2017 02:39 AM
Thank for your reply.
Once I have configured the primary and redundant WLC as a HA pair will the primary need a re-boot ?
Obviously if a re-boot is required then this will result in an interruption to services so I will need to be aware of this.
Paul
12-18-2017 03:04 AM
12-18-2017 03:09 AM
Thanks Leo, thought that might be the case.
Would I be right in thinking that the redundancy-management ip needs to be in the same subnet as the management ip ? as the management ip would then become the virtual ip address ?
Paul
12-18-2017 03:38 AM
Thanks All.
Got the answers confirmed to the questions above.
Paul
