Can VMWare Secure Access Control Servers be tracked in the SNTC portal?
Or is is excluded as it is SW?
You are correct, software
You are correct, software licenses and software applications are not currently supported by SNTC.  I also checked the Secure Network Server (hardware) for ISE, NAC, and ACS applications (SNS-3495-K9, SNS-3415-K9) and they are not supported by SNTC at this time either.
Thanks for the quick (and
Thanks for the quick (and detailed) response!
67
