Can we mix mandatory and optional field entries for file import?
Can we have devices with mandatory fields only and some other devices with mandatory and optional fields within the same CSV file used for file import?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Bronze
Hi Rita and Sandra,
That is correct, you can mix mandatory and optional field entries for file import. However, if you don’t have OS type and version, the alerts matching would be impacted.
June
I think you can. I have seen sample files with both.
Bronze
Hi Rita and Sandra,
June
93
