Data privacy
Hello All,
Is it possible to provide only hardware related information rather than provide software configuration.
Is there any option ??
Tash
1 ACCEPTED SOLUTION
Hi Tash,Information collected
Hi Tash,
Information collected from the devices depend on what is configured in the collection profile. If you mean from software configuration "show running" and "show start-up” like information then they are part of the default profile and will be collected depending on if the device credential are correctly configured. You can create a new profile and choose what information you want CSP-C to collect from the managed devices.
Jawaid.
1 REPLY
Hi Tash,
Jawaid.
182
