Licensing and Smartnet on WS-SVC-WISM2-K-K9
Samim
Hi all
I have a question regarding licensing/Smartnet for WS-SVC-WISM2-K-K9 card
I was told , in order to register additional licenses for WS-SVC-WISM2-K-K9 , you need to use the SN# of the chassis where card will be installed. Is that correct ?
How can i move my WS-SVC-WISM2-K-K9 around without force to move my chassis , if it is tied with the chassis ?
I have also noticed some SmartNet pricing for just WS-SVC-WISM2-K-K9 , or combo of chassis , supervisor and WS-SVC-WISM2-K-K9
Your help will be highly appreciated
Thanks in advance
Leo Laohoo
If you have to RMA your WiSM-2 card, you need to furnish the serial number of the 6500/6800 chassis.
You can move the WiSM-2 into different chassis as long as the chassis is covered under SmartNet.
Thank you for your answer  Leo,
Then best option is to SmartNet both chassis and linecard ( for free  IOS updates ) in case of failure of either, instead of just purchasing for WISM-2
Then best option is to SmartNet both chassis and linecard (for free  IOS updates) in case of failure of either, instead of just purchasing for WISM-2.
Yes.
