Licensing and Smartnet on WS-SVC-WISM2-K-K9
Hi all
I have a question regarding licensing/Smartnet for WS-SVC-WISM2-K-K9 card
I was told , in order to register additional licenses for WS-SVC-WISM2-K-K9 , you need to use the SN# of the chassis where card will be installed. Is that correct ?
How can i move my WS-SVC-WISM2-K-K9 around without force to move my chassis , if it is tied with the chassis ?
I have also noticed some SmartNet pricing for just WS-SVC-WISM2-K-K9 , or combo of chassis , supervisor and WS-SVC-WISM2-K-K9
Your help will be highly appreciated
Thanks in advance
Hall of Fame Super Gold
If you have to RMA your WiSM
If you have to RMA your WiSM-2 card, you need to furnish the serial number of the 6500/6800 chassis.
You can move the WiSM-2 into different chassis as long as the chassis is covered under SmartNet.
Thank you for your answer
Thank you for your answer  Leo,
Then best option is to SmartNet both chassis and linecard ( for free  IOS updates ) in case of failure of either, instead of just purchasing for WISM-2
Then best option is to SmartNet both chassis and linecard (for free  IOS updates) in case of failure of either, instead of just purchasing for WISM-2.
Yes.
116
