05-30-2014 06:28 PM - edited 03-03-2019 07:26 AM
I have one cisco SG500-52P 52 ports PoE.
This have one problem because network blocking in periods nonrecurring, in ocassions after of restart the switch repeat the blocking.
I Checked the temperature but is normal, and the log not have errors registred.
We used this Switch with Phones PoE GrandStream and have in use 20 ports.
05-31-2014 02:47 AM
Hi..
Can you describe detail your problem? Just on one port or all of port?
06-03-2014 10:49 AM
Hi febrianhangga.
are all port, I take one print paint of log, but I not see an error that says me because the network has fallen
