Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
cisco WS-C2960-24TC-S switch connectivity problam
I configured my cisco WS-C3750X-12S-S with ip routing and it is working properly. i configured  a cisco  WS-C2960-24TC-S  switch and connect both switches via Fiber. each switches can communicate with other end. i can connect to C3750X from my local WAN, all interfaces are working properly but i cant connect to L2 switch from WAN. please help me.
(test result pages attached)
Silver
I hope by L2 switch you mean
I hope by L2 switch you mean its SVI interface then only issue is the routing in this case.
*************Do rate Helpful posts***********
i update the question with
i update the question with  the test result pages. check those pls
Silver
can you enable debug ip on
can you enable debug ip on both switches and share it
there is more sub commands
there is more sub commands under debug ip. what command should i enable ?
Dearthe fast Ethernet
Dear
the fast Ethernet interface on the switch is meant only for OOB (out of band management) so this way you will not be able to route traffic. It will not communicate to any other subnets apart from the connected subnet. Its better you create a SVI in the switch and use that SVI for management purposes.
regards
Najeeb
306
