DHCP Server - DHCP Client
Hi , Use IP Helper IP address
Hi ,
 Use IP Helper IP address on Router 0
interface FastEthernet0/1
 ip address 100.100.101.254 255.255.255.0
 ip helper-address 100.100.100.1
Sandy
Silver
yes IP helper address is used
yes IP helper address is used to convert broadcast to unicate traffic and is the desired solution also you can use debugging feature available in  packet tracker to find where the packet is being stoped
***************Do rate helpful posts******************
IP helper address is required
IP helper address is required in your topology and it will resolve the issue
69
