Netflow
Can i use my wan interface ip as the netflow source ???
  • Solutions and Architectures
1 ACCEPTED SOLUTION
Hi, afaik with the "ip
afaik with the "ip netflow-export source" command you can use any sort of interfaces, but no IP.
example:
ip flow-export source TenGigabitEthernet0/0/0.920
ip flow-export version 5
ip flow-export destination (dest-ip) 9991
regards
Hi ,  What is your actual
Hi ,
 What is your actual requirement , what traffic you want collect ??
Sandy
example:
regards
If the source interface down
If the source interface down then.... What is the use of source interface
42
