cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Problemas Union de AP con la controladora
Buenos días,
Estoy teniendo problemas con el enlace de los AP con la Controladora.
Este es el resultado de un debug hecho en la controladora:
*Oct 13 10:19:57.965: f8:66:f2:92:93:d6 Discovery Request from 192.168.29.16:10558
*Oct 13 10:19:57.965: f8:66:f2:92:93:d6 Discovery Response sent to 192.168.29.16:10558
*Oct 13 10:19:57.965: f8:66:f2:92:93:d6 Received LWAPP DISCOVERY REQUEST to 54:75:d0:06:6c:80 on port '1'
*Oct 13 10:19:57.965: f8:66:f2:92:93:d6 Discarding discovery request in LWAPP from AP supporting CAPWAP
(Cisco Controller) >*Oct 13 10:22:17.094: f8:66:f2:92:93:d6 Discarding discovery request in LWAPP from AP supporting CAPWAP
*Oct 13 10:28:04.917: f8:66:f2:92:93:d6 Discovery Request from 192.168.29.16:10558
*Oct 13 10:28:04.917: f8:66:f2:92:93:d6 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*Oct 13 10:28:04.917: f8:66:f2:92:93:d6 Discovery Response sent to 192.168.29.16:10558
*Oct 13 10:28:04.918: f8:66:f2:92:93:d6 Received LWAPP DISCOVERY REQUEST to 54:75:d0:06:6c:80 on port '1'
*Oct 13 10:28:04.918: f8:66:f2:92:93:d6 Discarding discovery request in LWAPP from AP supporting CAPWAP
Todavia no estoy pudiendo implementar esta solución por este problema.
Podrian guiarme como solucionar el incoveniente?
Gracias
Etiquetas (3)
4 RESPUESTAS
Re: Problemas Union de AP con la controladora
Aqui paso datos del log que aparece en el AP:
*Oct 13 14:55:33.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 13 14:55:32.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.98.3 peer_port: 5246
*Oct 13 14:55:32.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct 13 14:56:02.007: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Oct 13 14:56:02.007: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 192.168.98.3 is reached.
*Oct 13 14:56:32.001: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.98.3:5246
*Oct 13 14:56:32.001: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct 13 14:56:42.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 13 14:56:42.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.98.3 peer_port: 5246
*Oct 13 14:56:42.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct 13 14:57:12.003: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Oct 13 14:57:12.003: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 192.168.98.3 is reached.
*Oct 13 14:57:42.001: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.98.3:5246
*Oct 13 14:57:42.001: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct 13 14:57:52.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 13 14:57:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.98.3 peer_port: 5246
*Oct 13 14:57:51.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
Hola Ivan,
Me puedes dar un poco más de información, ¿cuál es el modelo de la AP exactamente?
Ten en cuenta que los Wireless controllers no forman parte de la serie de Cisco Small business y se soportan por Cisco TAC. Así que cualquier problema relacionado con la configuración de la controladora debes contactar ellos. Aquí tienes los números: http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
Gracias por la respuesta.
Ya pude encontrar el problema. El IOS del AP no era compatible con el IOS de la controladora. Una vez hecho el upgrade de la controladora se pudo formar el tunel sin inconvenientes.
Senor Ivan,
Favor de presentar el modelo de su AP, para yo poder darle una una opinion educada al respecto...
704
Visitas
ÚTIL
Respuestas
CrearPor favor para crear contenido
