32-port line card B2B credits
When I setup an E-port on the first of the four ports in a quad , how can I allocate the number of B2B credits from default 12 to a higher number which are not used by the three disabled ports?
1 REPLY
Re: 32-port line card B2B credits
Hi Michal,
The receive BB_credit values depend on the module type and the port mode.
For 32-port switching modules and host-optimized ports, the default value is 12 for Fx, E, and TE modes. These values cannot be changed.
For 16-port switching modules and full rate ports, the default value is 16 for Fx mode and 255 for E or TE modes. The maximum value is 255 in all modes. This value can be changed as required.
Here is an example how to change it:
gislaved(config-if)# switchport fc
fcrxbbcredit fcrxbufsize
gislaved(config-if)# switchport fcrxbbcredit ?
<1-255> Enter receive BB_credit
default Default receive BB_credit
performance-buffers Configure performance buffers for receive BB_credit
gislaved(config-if)# switchport fcrxbbcredit 30 ?
mode Configure receive BB_credit for specific mode
Carriage Return
gislaved(config-if)# switchport fcrxbbcredit 30 mod e?
E
gislaved(config-if)# switchport fcrxbbcredit 30 mode ?
E Configure receive BB_credit for E or TE mode
Fx Configure receive BB_credit for F or FL mode
For further details, you may want to check out the following URL :
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/2_0/cliguide/part3/intf.htm#wp1142512
Hakan.
184
