9124 Port License
Trying to apply a port license to 9124 but everytime I try to add to the bootlash via TFTP I get the following error message
opy tftp://172.22.126.18:69 bootflash:
Enter source filename: MDS20090803081953790.lic
Trying to connect to tftp server......
Connection to server Established. Copying Started.....
TFTP get operation failed:Read-only file system
Please could someone point out where im going wrong
Re: 9124 Port License
Below is copying from a Windows server.
Check the permissions on the Shared folder, give everybody Change or Full control. On the NTFS permissions give Anonymous Logon Modifiy.
Check the permissions of the .lic file make sure that has not inhertied permissions from the folder it's in.
You might need to change that.
Cheers.
Its not the wi2k3 file system privs as I can tftp the lic file to volatile memory but not to bootflash
cant copy the file from voatile to bootflash either
copy volatile:MDS20090803081953790.lic bootflash:lic.lic
/bin/copy: cannot create regular file `/bootflash/lic.lic': Read-only file system
What about trying to Debug what is going on when you are trying to copy the file.
From the CLI run "debug system health bootflash" and then "no debug system health bootflash" when you are finished. That should tell you what is going on.
I just get the followig logs, nothing specific about copying the file.
2009 Aug 4 04:26:27.873258 SystemHealth: 2155:ohms_cf_start_test: Wrote req 0 seq# 9557. ret 40 errno 0
2009 Aug 4 04:26:27.874916 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD read seq# 9557
2009 Aug 4 04:26:27.875065 SystemHealth: 2197:ohms_cf_get_state: CF state active idle.
2009 Aug 4 04:26:27.875137 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD read state 2.
2009 Aug 4 04:26:27.875210 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD waiting to read
2009 Aug 4 04:26:27.875326 SystemHealth: 2155:ohms_cf_fd_activity: test 2 fd 23
2009 Aug 4 04:26:27.875404 SystemHealth: 2155:ohms_cf_fd_activity: Read from pipe, ret 40 errno 0 sseq# 9557 rseq# 9557
2009 Aug 4 04:26:27.875477 SystemHealth: 2155:ohms_cf_fd_activity: Current CF state = 2
2009 Aug 4 04:26:37.873125 SystemHealth: 2155:ohms_cf_start_test: test# = 2
2009 Aug 4 04:26:37.873251 SystemHealth: 2155:ohms_cf_start_test: Wrote req 0 seq# 9558. ret 40 errno 0
2009 Aug 4 04:26:37.874818 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD read seq# 9558
2009 Aug 4 04:26:37.874981 SystemHealth: 2197:ohms_cf_get_state: CF state active idle.
2009 Aug 4 04:26:37.875054 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD read state 2.
2009 Aug 4 04:26:37.875127 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD waiting to read
2009 Aug 4 04:26:37.875243 SystemHealth: 2155:ohms_cf_fd_activity: test 2 fd 23
2009 Aug 4 04:26:37.875321 SystemHealth: 2155:ohms_cf_fd_activity: Read from pipe, ret 40 errno 0 sseq# 9558 rseq# 9558
2009 Aug 4 04:26:37.875395 SystemHealth: 2155:ohms_cf_fd_activity: Current CF state = 2
2009 Aug 4 04:26:47.873104 SystemHealth: 2155:ohms_cf_start_test: test# = 2
2009 Aug 4 04:26:47.873274 SystemHealth: 2155:ohms_cf_start_test: Wrote req 0 seq# 9559. ret 40 errno 0
2009 Aug 4 04:26:47.874890 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD read seq# 9559
2009 Aug 4 04:26:47.875042 SystemHealth: 2197:ohms_cf_get_state: CF state active idle.
2009 Aug 4 04:26:47.875128 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD read state 2.
2009 Aug 4 04:26:47.875201 SystemHealth: 2197:ohms_cf_test_thread: CF THREAD waiting to read
2009 Aug 4 04:26:47.875319 SystemHealth: 2155:ohms_cf_fd_activity: test 2 fd 23
2009 Aug 4 04:26:47.875397 SystemHealth: 2155:ohms_cf_fd_activity: Read from pipe, ret 40 errno 0 sseq# 9559 rseq# 9559
Are you able to save the running config to startup config? In the 9216's the flash memory went into read only and the only way to fix it was with a reboot. Bug CSCeg75552.
You have checked there is enough space to copy the file to?
330
