03-15-2012 06:09 AM
dear everyone~
in project ,i need config MDS 9222i use 4 FCIP interface connect to 7606S 4 GE port for port-channel feature,but in MDS9222i i use port-channel commad ,cannot run。
how can i config it?
thinks~
Solved! Go to Solution.
03-15-2012 07:38 AM
Hi Sun,
Ethernet PortChannels are not supported on MSM-18/4 modules and 9222i IPS modules.
You can place the fcip interfaces in a fibre channel port-channel instead.
David
03-15-2012 07:38 AM
Hi Sun,
David
03-15-2012 06:05 PM
can you give me config document url or command template for fcip interfaces in a fibre channel port-channel?
thinks
