12-12-2011 08:59 PM
Can someone please help me understand advantages/disadvantages of MDS9513 compared to MDS9148
We are actually looking for a small datacenter deployment purpose and MDS9148 suits the requirement.
However I would like to understand if we can liverage any advantages in having a MDS9513 without all modules being populated.
12-14-2011 01:22 PM
advanced services like IVR, encryption, FCIP are not available on 9148 ..not enough buffer credits to use in DWDM connectivity scenario.
12-15-2011 01:06 AM
dynamox, thanks for your reply.
As per the data sheet i see, IVR and encryption are supported by 9148.
I am not sure on FCIP and buffer credits parts and got to check and come back.
12-15-2011 05:37 AM
this is interesting, take a look at these release notes
The Cisco MDS 9148 Multilayer Fabric Switch does not support the following NX-OS features:
•IVR
•Remote Span
•Translative loop support
•FCC - no generation, quench reaction only
•FC-Redirect
In addition, the following features have these limits:
•VSANs - 31 maximum
•SPAN - 1 session maximum
12-14-2011 02:42 PM
Obviously one big disadvantage of the 9513 over 9148 is the big cost difference.
Do you have cash to burn?
12-15-2011 01:16 AM
hi steven...ofcourse i understand cost factor.
Is it value for money is what i am trying to evaluate and expecting some expert comments
12-15-2011 05:56 AM
Hi Sandeep,
To make a good choice between the 9148 and the 9513 it really depends on these things:
* How many of
* What are you going to connect to it and
* how will this evolve over time?
This is akin to making the choice between a sports car and a small bus. While you may find both of those with similar prices, they serve completely different purposes.
Could you enlighten us about things such as:
- Which kind of storage are you attaching?
- Which kind of servers? Blade servers? Mainframe?
- How many ports do you think you will need now, in 1 year, in 3, in 5...
- What speed will the links be needing?
- Do you require high(er) availability
HTH,
Kris
12-20-2011 06:47 PM
Also to consider is the size (RU) difference...
9513 = need 15 RU with a rack-mount kit (almost half of your standard 42 RU rack)
9148 = just 1 RU.
Also, consider total power comsumption difference. In 95xx you can power off modules (line cards) when not used.
Nisar Sayed
12-22-2011 03:20 AM
Dynamox/Kris/Sayed - Thanks for your inputs
Kris - As mentioned in my question, it’s a small data center deployment and 9148 suits my requirement.
my typical setup would include, 30-40 UCS Blades with approx 10% of maximum growth rate per year and will be SAN attached to VNX/Clariion.
Dynamox - since there are some contradictions, I will follow up with my global account manager/network arch from cisco for more details.
will keep you guys informed if i get any useful info.
01-05-2012 06:08 PM
were you able to clarify the "features" part?
