Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
backplane speed on MDS 9509 director
in our environment we have a fully populated 9509 with 2 supervisors
the chassis we have a mix of 9032 (2Gb), 9148(4Gb), 9016(2Gb),9124(4Gb) line cards
would the backplane speed between line cards be limited to the lowest link speed?
i.e. going from the 9032 to the 9148 would be 2Gbps
Thank you
Re: backplane speed on MDS 9509 director
Not it will not. You can have a mix of different speed line cards in the same chassis.
please elaborate on your response
thanks
Hi Jie,
Prashanth is right, both linecards will operate at the speed indicated. Beware that the linecards will have some oversubscription (meaning that not all ports in a port group will be able to use their max speed at the same time)
Thanks for the response but I'm still not clear on the answer
I do understand that there will be oversubscription on the 48 & 24 ports if they're to operate at 4Gbps
when you say both cards will operate at the speed indicated, is that 2Gbps or 4Gbps?
don't the linecard communicate via the crossbar module?
Hi Jie,
Any given port will communicate with any other given port on the same switch at the maximum speed that _both_ can attain. A 2Gb port will not magically start working at 4Gb just because it's sending data to a device attached to a 4Gb port.
This holds true for as long as the link between the linecard and the crossbar is not saturated. This is what oversubscription in this case means: for a 4:1 oversubscription only a quarter of the ports can communicate with the backend at their maximum speed.  While this is oversimplified, it's a good general rule of thumb.
As for your particular case:  the backend of the switch will not force your 4Gb linecards to become 2Gb because there are earlier generation linecards present. You will however not be able to run all of your 4Gb port at an actual sustained data rate of 4Gb at the same time, but this is by design.
I hope this made things clearer for you
757
