12-12-2013 12:53 PM
Does anyone have steps on how to configure Nexus 5k for native fc to a storage controller? See topology:
[SERVER] hba <------> FC Port [NEXUS 5548UP] FC Port <-------> FC Port [STORAGE ARRAY]
Any info that anyone could provide regarding this would be greatly appreciated.
Solved! Go to Solution.
12-18-2013 03:01 AM
Hi Teddy
Assuming you use the last two ports as FC-ports:
feature fcoe (this includes the native FC-features)
slot 1
port 31-32 type fc
reload switch
vsan database
vsan 10
interface fc1/31-32
switchport mode F
no shut
vsan database
vsan 10 interface fc 1/31
vsan 10 interface fc 1/32
Check FLOGI:
show flogi database vsan 10 (you should see a flogi from each FC port)
ZONIG:
zoneset name ZS-VSAN-10 vsan 10
zone name Z1
member pwnn (PWNN of ARRAY)
member pwnn (PWNN of HBA)
zoneset activate name ZS-VSAN-10 vsan 10
Marcel
12-18-2013 03:01 AM
Hi Teddy
slot 1
port 31-32 type fc
reload switch
vsan database
vsan 10
interface fc1/31-32
switchport mode F
no shut
vsan database
Check FLOGI:
ZONIG:
zone name Z1
Marcel
01-21-2014 02:27 PM
Thank you very much!!!
04-16-2014 12:39 PM
Hi Teddy,
Can you pls share you Nexus 5548 config as I am also trying to connect my 5548up with an FC Storage array. But the ports on Nexus Switch are not coming up
I am connecting as below
Below link is ok But Below port on Nexus not coming up
Blade Server MDS Switch FC Port <-------> FC Port [NEXUS 5548UP] FC Port <-------> FC Port [STORAGE ARRAY]
04-16-2014 01:10 PM
can you provide the output of "show flogi database" and "show interface brief" ?
04-21-2014 01:47 AM
Hi wdey,
Pls find below
switch(config-if)# show flogi database
No flogi sessions found.
switch(config-if)# show interface brief
Interface Vsan Admin Admin Status SFP Oper Oper Port
Mode Trunk Mode Speed Channel
Mode (Gbps)
fc1/29 10 F on notConnected swl -- --
fc1/30 10 F on notConnected swl -- --
fc1/31 1 auto on trunking swl TE 4 --
fc1/32 10 F auto notConnected swl -- --
switch(config-if)# sh int fc1/32
fc1/32 is down (Link failure: loss of sync)
Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
Port WWN is 20:20:00:2a:6a:51:9a:c0
Admin port mode is F, trunk mode is auto
snmp link state traps are enabled
Port vsan is 10
Receive data field Size is 2112
Beacon is turned off
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
3676827 frames input, 147073080 bytes
0 discards, 0 errors
0 CRC, 0 unknown class
0 too long, 0 too short
0 frames output, 0 bytes
2 input OLS, 2 LRR, 0 NOS, 0 loop inits
170 output OLS, 2 LRR, 86 NOS, 0 loop inits
last clearing of "show interface" counters Tue Sep 22 08:24:49 2009
04-21-2014 11:32 AM
Can you please clarify
Blade Server<-----> MDS Switch FC Port <-------> FC Port [NEXUS 5548UP] FC Port <-------> FC Port [STORAGE ARRAY]
- Is this your topology ??
- I can see fc 1/31 as a trunking E-Port ! Is this where you connect your MDS ?
- I can't see any other fc connectivity ? on which port is your storage array connected ?
- are you using VSAN 10 for your host and storage connectivity ?
- show interface fc 1/31, we need to know, which VSAN's are allowed on that link. The ports themselfs are in VSAN 1 !!
04-22-2014 07:30 AM
Hi Wdey,
Thanks for reply. I want my blade to access my Storage through Nexus 5548up. Storage is connected to port fc 1/32 which shows "fc1/32 is down (Link failure: loss of sync)". Even if use VSAN 1 sitll same,
As you requested below is the fc 1/31
fc1/31 is trunking
Port WWN is 20:1f:00:2a:6a:51:9a:c0
Peer port WWN is 20:0e:00:05:73:a6:97:80
Admin port mode is auto, trunk mode is on
Port mode is TE
Port vsan is 1
Speed is 4 Gbps
Transmit B2B Credit is 16
Receive B2B Credit is 16
Trunk vsans (admin allowed and active) (1,10)
Trunk vsans (up) (1)
Trunk vsans (isolated) (10)
Trunk vsans (initializing) ()
1 minute input rate 240 bits/sec, 30 bytes/sec, 0 frames/sec
1 minute output rate 144 bits/sec, 18 bytes/sec, 0 frames/sec
186954 frames input, 15626828 bytes
186962 frames output, 9489756 bytes
0 input OLS, 10 LRR, 0 NOS, 0 loop inits
162 output OLS, 151 LRR, 0 NOS, 0 loop inits
last clearing of "show interface" counters never
16 receive B2B credit remaining
16 transmit B2B credit remaining
0 low priority transmit B2B credit remaining
Interface last changed at Thu Sep 17 19:27:56 2009
04-23-2014 12:16 AM
Something basic must be wrong with your port fc 1/32 connecting the storage; please check the following
- Is the port "no shut"
- is the port on the storage subsystem enabled
- are the MMF cables ok ?
- try swap cable send and receive
- is the sfp ok
- try another N5k port
04-23-2014 01:23 AM
Dear Wdey,
Thanks for your support. Its ok now it was from the storage side. The storage port was set to be as a loop port. So i changed it to point to point the it worked,
Hemant Bisht
