12-29-2006 10:45 PM
Greetings,
While trying to get SNMP traps running properly with Netview (if only I had Openview), I looked at using call home. Terrific product with the exception of one thing which probably does not affect the private sector. I would suggest that most government agencies need to have a classification of some sort in either the heading or the body of the email. I cant find anyway of doing that which means that the email will never get through. Would anyone know of a way to put certain words in the heading or body of the call home email? It may sound trivial but it would be a great leap forward in my view.
Stephen
12-30-2006 09:38 PM
If you have a set string prodided to you that will allow you to get through email filtering then I would put something in a user configurable field such as Customer, Contract, or Site ID.
these should be provided in the xml that is sent out.
docs
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/1_3_1/sw_confg/callhome.htm#wp1053095
--Colin
12-31-2006 12:09 AM
Colin,
I have tried everything regarding this issue. I even hoped that mucking about with call home on the host that you run FM from may do something but it has been to no avail.
Whenever I try to do anything, the email filter goes ballistic and notifies everyone of some sort of security problem.
BTW, if you want to share anything about your hope of getting a CCIE in storage, I started up a blog site today in order to teach some one eyed Brocade person the benefits of SAN-OS. I am not sure how it works yet but hey, it could be fun and hopefully share some info.
http://iluvmystorage.blogspot.com
There will be other stuff in there like my HDS equipment and how knows what else.
My email address is speter24 at tpg dot com do au.
Stephen
01-05-2007 01:38 PM
That is an odd one. Without knowing what rule you are breaking in the mail filters, I don't know how anyone could come up with a workaround.
I looked at your blog, it is pretty neat.
I did pretty much the same thing http://colinmcnamara.blogspot.com/
