DAC cable between HP Flex-10 and Cisco 4900M
We have HP C7000/VC-Flex 10 Module that I would like to connect to our Netapps NFS datastore.  The Cisco switch that I will be using between HP Flex-10 and Netapps is Cisco 4900M.  I have a HP cable AP784A direct attach copper SFP+ to SFP+.  Which module I need to purchase and insert into my 4900M to support 10Gb connectivity via HP DAC 10Gb cable.
Please Advise!
1 REPLY
Bronze
You need
4900M 4 port 10GE half card with X2 interfaces (WS-X4904-10GE)
    OR
4900M 8 port 10GE half card with X2 interfaces (WS-X4908-10GE)
WITH
Cisco OneX Converter Module Converts an X2 Interface into One SFP+ Interface (CVR-X2-SFP10G)
I would recommend you to use following DAC cables from Cisco.
• SFP-H10GB-CU1M: 10GBASE-CU SFP+ Cable 1 meter (Version -02)
• SFP-H10GB-CU3M: 10GBASE-CU SFP+ Cable 3 meter (Version -02)
• SFP-H10GB-CU5M: 10GBASE-CU SFP+ Cable 5 meter (Version -02)
935
