enabling lun zoning on MDS 9148
Hi all,
i am having troubles enabling lun zoning on MDS 9148..
according to configuration guide lun zoning should be siplmly enabled by entering lun id, at the end of the following command:
switch(config)#zone name LunSample vsan 2
switch(config-zone)#member pwwn  10:00:00:23:45:67:89:ab lun 0x64
when i try to do this , there is no option to enter the key word lun.., there are only following options:
switch(config-zone)# member pwwn 21:00:00:24:ff:0a:d3:b3 ?
  <CR>
  both       Enter device-type as both
  initiator  Enter device-type as initiator
  target     Enter device-type as target
i am running following NX-OS on my MDS 9148:
kickstart variable = bootflash:/m9100-s3ek9-kickstart-mz.5.2.8b.bin
system variable = bootflash:/m9100-s3ek9-mz.5.2.8b.bin
i have enterprise license installed. i have put it in use by enabling feature port-security, as far there is no such a feature as lun zoning
switch# sh license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                Yes   -   In use never       -
PORT_ACTIVATION_PKG           Yes  32   In use never       -
i just want to note, that there is no Storage attached yet, so the question is: is it possible that lun id will be available once the MDS switch will learn them from Storage??
any other suggestions?
Thank You..
  • Storage Networking
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: enabling lun zoning on MDS 9148
Lun zoning is not support on MDS 9148 (Sabre ASIC hardware does not support lun zoning functionality)
https://tools.cisco.com/bugsearch/bug/CSCuj56321
Symptom:
Correct documentation to note that LUN Zoning and read-only zones were removed at NX-OS 5.0(1) and above for the MDS 9148 platform.
Conditions:
N/A
Workaround:
Documentation only
More Info:
Resolution Summary:
When Resolved - Documentation Updated.
Vu
Hello Marek,
Since release 5.2(6) is required configure the device type (both, initiator, target).
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_2/command/reference/CR04_m.html#wp1256687
Richard
Hello Marek,
Since release 5.2.1 and later lun zoning is no longer supported. your release is 5.2.8b
Zoning Features
LUN zoning, read-only zones, and broadcast zones are no longer supported. These features affect the following hardware:
Cisco MDS 9000 8-port 10-Gbps Fibre Channel over Ethernet (FCoE) module
Cisco MDS 9000 48-port 8-Gbps Advanced Fibre Channel Switching module
Cisco MDS 9000 32-port 8-Gbps Advanced Fibre Channel Switching module
You cannot bring up these modules if these features are already configured. You should completely remove all configurations that include these features before you attempt to bring up these modules. In addition, you cannot configure these features after you bring up these modules.
Symptom:
Conditions:
N/A
Workaround:
Documentation only
More Info:
Resolution Summary:
Vu
Thank you Vu Phan, unfortunately the main documentation is not clear about it.
741
