10-15-2014 03:41 AM
I have been trying to perform an NDMP backup between A HP LTO5 Ultrium Tape Library and Netapp with the MDS switch providing the fabric.
However, everytime I initiate the job, I experience this problem.
Below are some of the outputs on the concerned FC Ports:
MDS-SW01# sh int fc1/27
fc1/27 is down (Error disabled - bit error rate too high)
Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
Port WWN is 20:1b:54:7f:ee:e2:8d:00
Admin port mode is auto, trunk mode is on
snmp link state traps are enabled
Port vsan is 2
Receive data field Size is 2112
Beacon is turned off
5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
263045 frames input, 12907156 bytes
0 discards, 0 errors
0 CRC, 0 unknown class
0 too long, 0 too short
4308477 frames output, 8677425352 bytes
1 discards, 0 errors
2 input OLS, 2 LRR, 0 NOS, 3 loop inits
5 output OLS, 2 LRR, 1 NOS, 3 loop inits
Interface last changed at Mon Oct 13 07:36:46 2014
MDS-SW01# sh int fc1/27 counters
fc1/27
0 class-2 frames, 0 bytes
263045 class-3 frames, 12907156 bytes
0 class-f frames, 0 bytes
0 discards, 0 errors, 0 CRC
0 unknown class, 0 too long, 0 too short
4308477 class-3 frames, 8677425352 bytes
1 link failures, 1 sync losses, 1 signal losses
9 BB credit transitions from zero
32 receive B2B credit remaining
0 transmit B2B credit remaining
0 low priority transmit B2B credit remaining
What could be causing the issue and what is the solution?!
Thanks.
Solved! Go to Solution.
12-16-2014 12:21 AM
hi,
If SFPs have been replaced, it's time for the cables and patch-panels.
10-15-2014 11:09 AM
Is this the same problem, as discussed under
https://supportforums.cisco.com/discussion/12322531/cisco-mds-switch-port-unavailable ??
and
https://supportforums.cisco.com/discussion/12322021/nexus-5548-lto3-tape-drives-interface-down
Please provide a drawing of the configuration, with
- FC port type, speed, medium (show interface of every FC port, tape as well as Netapp)
- show flogi database
- is there a FC speed mismatch between tape and Netapp ?
10-16-2014 08:21 AM
Hi wdey,
This is same case as https://supportforums.cisco.com/discussion/12322531/cisco-mds-switch-port-unavailable!
MDS Output
MDS-SW01# sh flo dA
INTERFACE VSAN FCID PORT NAME NODE NAME
fc1/1 2 0x640000 21:00:00:24:ff:47:86:a8 20:00:00:24:ff:47:86:a8
fc1/2 2 0x641000 50:0a:09:82:9d:ef:09:57 50:0a:09:80:8d:ef:09:57
fc1/3 2 0x641d00 21:00:00:24:ff:47:d2:c9 20:00:00:24:ff:47:d2:c9
fc1/4 2 0x640300 21:00:00:24:ff:48:8d:f9 20:00:00:24:ff:48:8d:f9
fc1/5 2 0x640a00 21:00:00:24:ff:48:8b:1e 20:00:00:24:ff:48:8b:1e
fc1/6 2 0x640800 10:00:00:00:c9:86:ce:31 20:00:00:00:c9:86:ce:31
fc1/7 2 0x640600 10:00:00:00:c9:8f:37:ad 20:00:00:00:c9:8f:37:ad
fc1/8 2 0x642500 21:00:00:24:ff:40:8c:ad 20:00:00:24:ff:40:8c:ad
fc1/9 2 0x640d00 21:00:00:24:ff:48:89:80 20:00:00:24:ff:48:89:80
fc1/10 2 0x641100 10:00:00:00:c9:88:c3:6a 20:00:00:00:c9:88:c3:6a
fc1/11 2 0x640e00 21:00:00:24:ff:48:8d:fc 20:00:00:24:ff:48:8d:fc
fc1/12 2 0x641200 50:0a:09:81:8d:ef:09:57 50:0a:09:80:8d:ef:09:57
fc1/13 2 0x641300 10:00:00:00:c9:8f:32:50 20:00:00:00:c9:8f:32:50
fc1/14 2 0x641400 10:00:00:00:c9:8c:bf:b2 20:00:00:00:c9:8c:bf:b2
fc1/15 2 0x641700 21:00:00:24:ff:47:cf:82 20:00:00:24:ff:47:cf:82
fc1/16 2 0x641e00 50:0a:09:80:01:5e:25:98 50:0a:09:80:01:5e:25:98
fc1/18 2 0x641b00 21:01:00:1b:32:21:e8:99 20:01:00:1b:32:21:e8:99
fc1/19 2 0x641a00 50:01:04:f0:00:cb:ec:81 50:01:04:f0:00:cb:ec:80
fc1/20 2 0x641c00 10:00:00:00:c9:9e:2b:f4 20:00:00:00:c9:9e:2b:f4
fc1/22 2 0x642000 20:1f:00:2a:6a:7c:48:80 20:02:00:2a:6a:7c:48:81
fc1/22 2 0x642001 20:00:00:25:b5:11:1a:00 20:00:00:25:b5:11:00:08
fc1/22 2 0x642002 20:00:00:25:b5:11:1a:02 20:00:00:25:b5:11:00:0a
fc1/22 2 0x642008 20:00:00:25:b5:11:1a:04 20:00:00:25:b5:11:00:0c
fc1/22 2 0x642010 20:00:00:25:b5:11:1a:06 20:00:00:25:b5:11:00:0e
fc1/23 2 0x642300 50:0a:09:81:88:fa:b7:9a 50:0a:09:80:88:fa:b7:9a
fc1/24 2 0x641f00 20:20:00:2a:6a:7c:48:80 20:02:00:2a:6a:7c:48:81
fc1/24 2 0x641f01 20:00:00:25:b5:11:1a:01 20:00:00:25:b5:11:00:09
fc1/24 2 0x641f02 20:00:00:25:b5:11:1a:03 20:00:00:25:b5:11:00:0b
fc1/24 2 0x641f04 20:00:00:25:b5:11:1a:05 20:00:00:25:b5:11:00:0d
fc1/24 2 0x641f08 20:00:00:25:b5:11:1a:07 20:00:00:25:b5:11:00:0f
fc1/27 2 0x641900 50:01:04:f0:00:cb:ec:8e 50:01:04:f0:00:cb:ec:8d
MDS-SW01# sh int fc1/27 (Tape connected here)
fc1/27 is up
Port mode is F, FCID is 0x641900
Port vsan is 2
Speed is 4 Gbps
Rate mode is dedicated
Transmit B2B Credit is 8
Receive B2B Credit is 32
5 minutes input rate 6896 bits/sec, 862 bytes/sec, 1 frames/sec
5 minutes output rate 504 bits/sec, 63 bytes/sec, 1 frames/sec
2057274 frames input, 96810136 bytes
33868435 frames output, 68232891832 bytes
37 discards, 0 errors
6 input OLS, 6 LRR, 0 NOS, 27 loop inits
12 output OLS, 3 LRR, 3 NOS, 7 loop inits
8 transmit B2B credit remaining
8 low priority transmit B2B credit remaining
Interface last changed at Thu Oct 16 08:00:54 2014\
MDS-SW01# sh int fc1/23 (Netapp connected here)
fc1/23 is up
Port WWN is 20:17:54:7f:ee:e2:8d:00
Port mode is F, FCID is 0x642300
Port vsan is 2
Speed is 4 Gbps
Transmit B2B Credit is 3
5 minutes input rate 814872 bits/sec, 101859 bytes/sec, 337 frames/sec
5 minutes output rate 10494656 bits/sec, 1311832 bytes/sec, 796 frames/sec
13668826268 frames input, 18767974115904 bytes
24873403718 frames output, 46226980943856 bytes
25 discards, 0 errors
2 input OLS, 0 LRR, 0 NOS, 7 loop inits
7 output OLS, 7 LRR, 6 NOS, 7 loop inits
3 transmit B2B credit remaining
3 low priority transmit B2B credit remaining
Interface last changed at Thu Oct 16 06:54:13 2014
Tape Data:
The info for the tape Library has been a challenge to retrieve, however, Documentation states that the FC Port can support upto 4GB. On the SL Console, it is showing that it is in Auto! With N_mode.
Netapp Extract.
slot 0: Fibre Channel Target Host Adapter 0b
(QLogic 2432 (2462) rev. 2, <ONLINE>)
Firmware rev: 5.5.2
Host Port Addr: 642300
Connection: PTP, Fabric
Switch Port: ---------
SFP Vendor Name: AVAGO
SFP Vendor P/N: AFBR-57R6APZ-NA1
SFP Vendor Rev:
SFP Serial No.: AVAGCN09074826DP
SFP Connector: LC
SFP Capabilities: 1, 2, 4 Gbit/Sec
I/O base 0x00009800, size 0x100
memory mapped I/O base 0xfe0fc000, size 0x4000
#fcp show adapter -v
Slot: 0b
Description: Fibre Channel Target Adapter 0b (QLogic 2432 (2462) rev. 2)
Status: ONLINE
Host Port Address: 0x642300
Firmware Rev: 5.5.2
FC Packet Size: 2048
Data Link Rate: 4 GBit
Adapter Type: Local
Fabric Established: Yes
Connection Established: PTP
Mediatype: auto
Partner Adapter: None
Standby: No
Target Port ID: 0x1
Switch Port: ----------
We set the speed on the MDS switch to 4GB on the port where the tape library is connected, hoping to address the speed mismatch, but still had same issue!
Here are some of the logs off the MDS switch!
2014 Oct 1 01:53:12 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/20 is down (Link failure)
2014 Oct 1 01:55:53 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/20 is down (Link failure)
2014 Oct 1 01:55:53 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/20 is up in mode F
2014 Oct 1 02:01:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/20, Low Rx Power Warning
2014 Oct 1 02:01:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/20, Low Rx Power Alarm
2014 Oct 1 02:11:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/20, Low Rx Power Warning cleared
2014 Oct 1 02:11:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/20, Low Rx Power Alarm cleared
2014 Oct 1 03:41:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 1 03:41:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 1 20:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 1 20:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 1 21:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 1 21:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 2 08:16:40 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 2 08:18:47 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 2 08:18:47 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 2 08:21:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 2 08:21:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 2 08:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 2 08:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 3 08:39:27 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct 3 08:41:59 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct 3 08:41:59 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/10 is up in mode F
2014 Oct 3 08:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning
2014 Oct 3 08:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm
2014 Oct 3 09:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning cleared
2014 Oct 3 09:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm cleared
2014 Oct 3 19:21:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 19:21:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 3 19:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 19:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 3 19:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 19:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 3 20:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 20:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 3 20:11:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 20:11:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 3 20:21:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 20:21:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 3 21:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 21:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 3 22:01:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 3 22:01:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 6 01:31:20 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 6 01:33:27 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 6 01:33:27 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 6 01:41:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 6 01:41:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 6 01:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 6 01:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 7 02:02:27 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct 7 02:04:57 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct 7 02:04:57 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/10 is up in mode F
2014 Oct 7 02:11:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning
2014 Oct 7 02:11:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm
2014 Oct 7 02:21:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning cleared
2014 Oct 7 02:21:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm cleared
2014 Oct 8 10:26:38 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/25-1/25 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
vice error 0xc7f00503)
2014 Oct 8 10:26:38 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/25 is down (Error disabled - bit error rate too high)
2014 Oct 9 00:52:52 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct 9 00:52:54 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct 9 00:52:54 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/26 is up in mode F
2014 Oct 9 00:53:02 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 00:53:06 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 00:53:06 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 00:53:12 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 00:53:16 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 00:53:16 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 00:54:01 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct 9 00:54:09 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct 9 00:54:09 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/26 is up in mode F
2014 Oct 9 01:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning
2014 Oct 9 01:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm
2014 Oct 9 01:11:37 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct 9 01:11:42 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct 9 01:11:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning cleared
2014 Oct 9 01:11:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm cleared
2014 Oct 9 01:14:08 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/10 is up in mode F
2014 Oct 9 01:14:36 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/26 is down (Error disabled - bit error rate too high)
2014 Oct 9 01:14:36 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/26-1/26 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 9 01:21:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning
2014 Oct 9 01:21:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm
2014 Oct 9 01:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning cleared
2014 Oct 9 01:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm cleared
2014 Oct 9 01:32:24 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 01:35:50 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 01:35:50 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 05:17:26 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:17:30 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:17:30 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 05:17:34 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:17:38 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:17:38 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 05:18:17 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:21:51 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:21:51 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 05:25:56 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:26:00 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:26:00 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 05:26:37 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:26:44 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 05:26:44 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 05:29:03 --MDS-SW01 %PORT-5-IF_DOWN_NONE: %$VSAN 4094%$ Interface fc1/25 is down (None)
2014 Oct 9 05:29:09 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 9 05:29:58 --MDS-SW01 %PORT-5-IF_DOWN_NONE: %$VSAN 4094%$ Interface fc1/26 is down (None)
2014 Oct 9 05:30:05 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 9 05:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning
2014 Oct 9 05:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm
2014 Oct 9 05:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning cleared
2014 Oct 9 05:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm cleared
2014 Oct 9 05:57:57 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 9 06:00:04 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 9 06:00:04 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 9 06:01:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 9 06:01:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 9 06:11:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 9 06:11:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 9 06:18:22 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 06:18:32 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 06:18:32 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 06:18:39 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 06:18:49 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 06:18:49 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 06:20:46 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 9 06:20:46 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/28 is down (Link failure)
2014 Oct 9 06:20:46 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/27 is down (Link failure)
2014 Oct 9 06:22:09 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 9 06:22:11 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 9 06:24:06 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 9 06:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning
2014 Oct 9 06:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm
2014 Oct 9 06:41:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning cleared
2014 Oct 9 06:41:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm cleared
2014 Oct 9 07:06:44 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 9 07:06:44 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 9 07:36:52 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 9 07:36:52 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 10 04:34:16 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/27 is down (Administratively down)
2014 Oct 10 04:34:20 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 10 04:34:20 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 10 04:34:29 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 10 04:34:32 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 10 04:34:32 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 10 05:41:08 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 10 05:43:15 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 10 05:43:15 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 10 05:51:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 10 05:51:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 10 06:01:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 10 06:01:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 12 22:11:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:11:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 12 22:21:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:21:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 12 22:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 12 22:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 13 06:02:24 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:04:32 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:04:32 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 13 06:11:21 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:18:17 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:18:17 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 13 06:21:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 13 06:21:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 13 06:28:25 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 13 06:28:26 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 13 06:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 13 06:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 13 06:35:18 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:38:10 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:38:10 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 13 06:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 13 06:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 13 06:42:35 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 13 06:42:38 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 13 06:42:39 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 13 06:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 13 06:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 13 07:36:46 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 13 07:36:46 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 13 08:02:41 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 13 08:02:41 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 02:16:18 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 14 02:19:44 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 14 02:19:44 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 14 03:03:22 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/27 is down (Administratively down)
2014 Oct 14 03:03:27 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:03:27 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 14 03:03:35 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 14 03:03:37 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:03:37 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 14 03:17:25 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 03:17:25 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:42:06 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:42:06 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 06:23:29 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 14 06:27:39 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 14 06:27:39 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 14 06:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 14 06:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 14 06:34:15 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/27 is down (Administratively down)
2014 Oct 14 06:34:18 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 06:34:18 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 14 06:34:25 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 14 06:34:27 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 06:34:27 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 14 06:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 14 06:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 14 07:24:15 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 07:24:15 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 08:04:18 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 08:04:18 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
10-16-2014 08:51 AM
The error log file is full of events, like
followed by interface down / up,........
I see this for interface 1/19, 1/20, 1/18, 1/10, 1/25, 1/26.
The traffic flow is not going directly from disk (Netapp) to tape, but disk (Netapp) - Backup server - Tape ? correct ?
RX power warning : either you have wrong (single mode) patch cables; dirty connectors; broken SFP's; something at the physical layer is wrong.
If this is not fixed, you will have problems.
10-16-2014 10:34 PM
The traffic flow is flowing directly from disk (Netapp) to tape, through the Fabric (MDS). The two are zoned, accordingly. The type of traffic involved is NDMP data!
We will look at the physical layer and try to address the Rx Power warning, thank you for pointing that out.
Any word on the 'errDisable'?!
10-16-2014 11:00 PM
I think once you have fixed the physical problems (RX power issues), error disable will be gone.
10-16-2014 11:35 PM
I do not see any such errors on the ports that are involved in the design! I.e ports 23 and 27 or 28!
Do you suggest the Rx issue is system wide?!
Kindly advise the main suspects with the ErrDisable error?! The possible causes.
10-16-2014 11:51 PM
The following ports show RX power alarms:
FC 1/20, 1/12, 1/18, 1/10, 1/19
Can you please post the transceiver details ? show int fc1/28 transceiver
Cisco SFP's parts ? are the patch cables MMF ?
10-17-2014 04:16 AM
hi wdey,
below is infor on the transceivers connected to the library.
MDS-SW01# sh int fc1/28 transceiver
fc1/28 sfp is present
Name is CISCO-AVAGO
Manufacturer's part number is SFBR-5780APZ-CS2
Revision is G2.3
Serial number is AGA1719889N
FC Transmitter type is short wave laser w/o OFC (SN)
FC Transmitter supports short distance link length
Transmission medium is multimode laser with 62.5 um aperture (M6)
Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s
Nominal bit rate is 8500 Mb/s
Link length supported for 50/125mm fiber is 50 m
Link length supported for 62.5/125mm fiber is 20 m
Cisco extended id is unknown (0x0)
No tx fault, rx loss, in sync state, diagnostic monitoring type is 0x68
SFP Diagnostics Information:
Temperature : 0.00 C
Voltage : N/A
Current : 0.00 mA
Optical Tx Power : N/A dBm
Optical Rx Power : N/A dBm
Tx Fault count : 0
Note: ++ high-alarm; + high-warning; -- low-alarm; -low-warning
MDS-SW01# sh int fc1/27 transceiver
fc1/27 sfp is present
Name is CISCO-AVAGO
Revision is G2.3
Serial number is AGA1719889Y
No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68
Voltage : N/A
Current : 0.00 mA
Tx Fault count : 0
10-17-2014 04:26 AM
Are your patch cables MMF 50/125 or 62.5/125 ?
10-17-2014 06:17 AM
Hi the cable is MMF 50/125! Any line of thinking?!
10-17-2014 09:44 AM
That's ok (max 50 m); do you have any sharp bend radius ?
11-02-2014 09:49 PM
Sorry wdey,
I was away for a while.
There are no sharp bends, that we have noticed.
11-27-2014 03:00 AM
Hey,
I tried change of SFPs from Finisar to Cisco Shortwave to not much effect! Only improvement was that a little more data was transferred (initially 50 GB now 250 GB) before the link drop!
Any thoughts?
12-16-2014 12:21 AM
hi,
