12-05-2008 01:11 PM
Fabric Manager SA not updating 3.3(1c). When I make zone changes or when a port goes down it won't update even after doing a rediscover or resync. Is this a bug in FM 3.3(1c)?
12-05-2008 08:36 PM
When FM was installed, was the option to continuously monitor the fabric after is was discovered? Not sure if this is your issue.
If you exit and then log back into FM after the change occurs, and is not observed, does the change show up? If the change is still not seen then I would suspect a bug and ask you to open a case with your MDS service provider. If the change is seen upon the new log in, then I would look into the option to 'monitor continuously'.
Hope this helps,
Mike
12-09-2008 02:00 PM
I have a opened up a ticket with TAC, and they are testing
